53 Ford flip nose
Re: 53 Ford flip nose
slowlylearning wrote:Grab some 2mm styrene and cut some circles out that are sorta the right size for the sleeves, but not too small to fit in. Drill a hole throught the middle and mount a circle on a sanding-disk holder bit for your dremel, then you can 'turn' out a blank 'smoothie' that fits perfik, then it's just a matter of plugging up the center hole, adding lugs and cutting in some spokes.
Looking good so far, I agree about the scoop, perfect attitude-adder :twisted:
Will have to give that a try KC, I'll take a rim to 'Spotlight' and check out some buttons as well, seen that done before ;)
