N-scale Layout
Re: N-scale Layout
Just playing around with photos.
Re: N-scale Layout
Looking good
I like how you have a clear vision of where your going with the project
Re: N-scale Layout
Re: N-scale Layout
Thank's Sandboarder, Luke, Ya cars are tiny wait untill you see the people magnify
got to buy some , Green car is a Benz.
Re: N-scale Layout
Doing a bit more to the second building, no photos yet.
Re: N-scale Layout
Added another set of points to oval so now have three short tracks to hold the three Diesels before had one sitting on the main line, Got to look at away to pin down the track as I am using a foam board base track pins keep more up and down, Will look at gluing track down with white glue.
Re: N-scale Layout
Been having trouble with the power on the layout, so after getting help I moved the power feeder 30" to the left just pass the points and problem fixed
now to get anther set of points after I got a bit of heavy handed and broke them. yes!
Re: N-scale Layout
Hit a big hick up with this one as I have used Foam Board for the base the track keeps lifting up and down track pins wont stay in place, Used glue and even double side tape but it wont hold so building a timber frame and going to get a sheet of plywood, Foam Board sounded a good idea but its been a pain in the rear end.
There is parts on the surface that I painted and its still sticky
should be well dry by now too.
Re: N-scale Layout
Made a new base board same size as the old one, Will make a few changes to it got to get some light grey to paint under the track.
Re: N-scale Layout
Got the grey coat down this afternoon & track back in place just need to tack it down now.
