57 Chevrolet pickup truck
This is a old build that I been working on, After I painted the cab found out the windscreen did not fit, So now the cab has been striped back to work on fitting the glass.
Will be repainting it the same colours.
Re: 57 Chevrolet pickup truck
Put a bit of thin plastic card on the bottom of the windscreen frame, its enough to help the glass fit in place, once painted and glass in place you wont see it, crossed
thumbsup Good to see you tackle and issue with a build and solve the problem hi5
Keep at it mate.
Looks good!! Just remember to do another test for before paint. I’ve made the mistake before
I have two more waiting to be built up and both have the same problem and now no about the problem will be about to fix it before the paint goes on.
Got to buy some of the blue paint to finish it now.
sandboarder wrote: Sat Jun 01, 2019 1:21 pm Looks good!! Just remember to do another test for before paint. I’ve made the mistake before
agreed whathesaid also sometimes need to allow for primer paint thickness
B61 MACK wrote: I have two more waiting to be built up and both have the same problem and now no about the problem will be about to fix it before the paint goes on.
Thats it Allan test and try out, to fix an issue hi5 thumbsup
What blue you going to use ??
Will be using Tamiya Acrylic X-2 White on the roof top the rest will be Tamiya Acrylic X-4 Blue which is a dark blue.
The first one of these I built back in 1992 the glass did not fit the top so I put the sun visor on it so you could not see the two mm gap, This kit does not have the sun visor.
Got the blue for this one today.
Must be going mad I worked on the windscreen frame for this one for a few days, This morning I got it out to have another look at it and found the glass does not fix anymore WTF pullinghair if I did not know better I say the glass has shrunk :roll: crazy So I put some Tamiya putty around the opening, Will give it a week before I shape it to refit the glass.
