Old Shed
Old Shed
Working on a old shed for Ute.
It will be 25cm wide.
25cm deep.
wall height will be 10cm.
the middle of the roof will be 15cm.
door will be 15cm wide.
Here is a rough drawing of the front of the shed.
Oh frame will be made out of 3mm square balsa wood.
Re: Old Shed
popcorn will be watching and look forward to seeing what you come up with.
Re: Old Shed
Might have to buy hot glue gun to glue it together. thinking
Re: Old Shed
Working on the base board for the Shed reusing some foam core board, Put some fine gravel down wet it down with spray bottle then used a mix of PVA Glue and water to hold it in place.
Will add grass around the edges the stuff I use on my layouts.
Re: Old Shed
Off to good start thumbsup
Re: Old Shed
Now the fun begins :lol:
Re: Old Shed
Good to see some progress, should be fun building the frame work.
Re: Old Shed
That will be fun to do not :lol:
Not going to rush it.
Size of base is 60cm by 60cm.
Re: Old Shed
Making a small change to the shed going to make it a simpler, here is one side wall.
Used balsa wood and have mark it in 5mm to look like weather boards and put marks in it with pencil.
And now the fun begins with pastels.
Re: Old Shed
once i am happy with the colour I seal it with a coat of dullcoat.
