HO-scale Building
HO-scale Building
Been working on this one for my HO layout.
Its a second hand one that I go cheap.
I just bought the two Mini's.
The roof is only sat in place for photos still got to put window glass in place.
Re: HO-scale Building
That’s looking great!! Have you done much to it or is it OOB? That’s going to build up fantastic
I put a black wash in the bricks the dry brushed four different colours on them,
Light black washed the roof and dry brushed light grey on the edges of the tiles that are up a bit, The grass around the base has two shades of green but not happy with the out come of it will glue down some grass that I used on the base board of the layout.
Also will look at using the dry pastels on some of the brick work and roof too then seal with dull coat.
Each part had to be clean up as there is a lot of flashing and the roof has small circles all over it, very hard to remove them yes!
Still a lot to do on it yet before I put the window glass in place. yes!
A lot better the N-scale :lol:
Oh roof was just sat in place for photo. yes!
This will be the next one to be built, been after it for some time.
I thought you had put some work into it. The dry brushing looks great thumbsup
Looking forward to seeing the progress on these.
Was not happy with the black wash on the roof so redid and will have to go back over the tiles edges and dry brush it again.
Worked on the grass around the base, got to wait a few days for it to dry now before I rework the wash on the bricks.
Re-black wash the bricks and add a bit more shrubs one the side.
I was check out the rear half of the building and found there is a large slide door missing and found parts that does not belong to this kit. Might have to make up a door.
Just painted the tin roof in metallic grey and there is more pimps the you find on a teen age kids face rofl did not see the pimps until the paint went on. yes! will be working on all the timber this afternoon and brick work is done. yes! For a very old kits it's coming together nicely bit like a AMT kit :lol: needs a lot of work to get it built. rofl
It’s looking great so far Al thumbsup keep at it popcorn
