HO-scale / OO-scale, N- Scale.
Re: HO-scale
Now the fun part begins in the track and turning it into a layout with builds, trees, grass etc.
Re: HO-scale
This will be the next building after the brick one is done.
Re: HO-scale
Had a look in the box and found there is two front walls for it and two front porch roofs the one in the photo and a hip one which I use, looks like you can buy two of the same kit and build two different house's. Will be building this one as a farm house.
Got to find a shed and garage or build the out of plastic card.
Re: HO-scale
Looking forward to seeing your work in progress
Re: HO-scale
Been working on the brick building today putting in the window frames.
This House is all white plastic and window frames the roof is light grey tile and the bottom brick work around the house is a very light off white colour, still
on colours for it.
Pick up a packet of track pins to tack the track down.
Re: HO-scale
Tell ya having Deyslexia is a pain in the butt at times yesterday I started to put the window glass behind the frames, As I counted the windows and the glass I get two different numbers and looked like I was going to be short of glass
So I just started to put the glass in and
on what to do if I come up short, guess what me not going to be short at all
got most of the window glass in place.
The new 38 class steam line Loco is coming out in all black and has thin red pin stripping and it's number will be 3803
Got one on order.
Got one on order.
Re: HO-scale
This is what the new 38 will look like this is the real one.
Re: HO-scale
That’ll look good
Re: HO-scale
Got the front windows finished with curtains and blinds just need to work on the others and add roof and a few little bits and it's done.
Ya going to look great with the other one.
Re: HO-scale
Almost done just need to put black backing on the small bottom windows and chimney on the roof and glue the roof in place.
Will look at a fire stair case for the side of the building ?
The front and rear windows had blinds and curtains but not for the side ones, so I put tamiya masking tape on the inside of the glass then put a bit of paint on it to help stop light from shining through.
