First of all you want a really clean molded kit or use Luke's clean up tips here http://www.kustomvinyls.com/forum/phpBB ... ?f=26&t=94 to make it easier on yourself. My Monogram issue Nomad is bad and i'm paying for it here.
So cut the BMF to size, im always generous seeing as its readily available for about $12 a sheet online. Gently rub with a cotton tip until its smooth and your happy. Then DRAG a tooth pick over the grooves to help push it in tight. NEVER push the tooth pick as you'll tear the BMF. Then using a new blade cut the excess of and try to only cut the foil and not into the paint (This is where a new blade helps)
Here's some pictures
and before you know it your transforming the model into something else. I still have heaps to BMF on this.
other hints n tips welcome
