Warhammer 40K Space Marines started pack
Re: Warhammer 40K Space Marines started pack
Looking the part would not known it was done with a brush.
2 coats of the Abaddon Black
2 coats of Balthasar Gold
Just the white to go and the base coats are finished
Crimany you're good that this! It looks so cool so far!!
2 coats of Corax White, lots of back n forth with the white and blue here to get straight lines!!
Here’s the wet palette so far
Next step will be the shade paint. Which is basically a panel line wash type. I’ll try and only paint it into the recess crossed
I don’t know about that but I’m actually enjoying brush painting which is something I normally hate (I was using rattle cans for everything) I found the wet palette has helped a lot. Easier to thin paints, control how much is on your brush and will be handy for mixing the colours for highlights. Definitely finding the Citadel paint to be great.
Looking good.
The wet palette works great.
Before;
After one coat of Agrax Earthshade;
And in the sunlight
So the shade paint are translucent colours designed to filter and gather in the recess’. I tried to stick to the panel lines but got a bit messy, I’ll either touch up the excess or hide it under edge highlights.
And in the sunlight
I would leave it as it is looks like a bit of weathering on it. yes!
